Thats BS. Even if the pads are ceramic which I don't believe they are, they still should'nt squeak as you describe. I replaced the dust dropping brembos pad on mine with Hawk PC's right after I got the car. 3500 miles later not a peep. You may try to do a few controlled hard stops to try and re-bed the pads. If that doesn't work find another dealer that will work with you. Good luck.
