Would an ecm from a srt make an rt run better? I know you would have to have the vin flashed in to it. Also has any one had b&g chrysler flash there ecm? Thanks
I'm speaking from my Charger experience and I assume the Challenger is no different. The SRT8 PCM wil not work on the R/T. Everything looks identical, but it's not. The wires are exactly the same inside the wiring harness but they go to different pins in the connectors. I have a wiring schematic for the Charger and on every page it has (except SRT8) in parenthesis. The SRT8 always has the same wires going to a different set of pins than on the R/T.Would an ecm from a srt make an rt run better? I know you would have to have the vin flashed in to it. Also has any one had b&g chrysler flash there ecm? Thanks
Lots of 5.7's have been swapped out for 6.1's, 6.4's, etc.... but, they all still use the 5.7 PCM. They just tweak the timing and fuel curves to meet the higher demands of the larger engine.so no question is a valid question? nobody has ever put a 6.1 based engine in an R/T ever? And they would be retarded to think they might want to I suppose.
I don't believe there is a Mopar performance PCM for the Challenger. With the Predator, no need for one anyway.Lots of 5.7's have been swapped out for 6.1's, 6.4's, etc.... but, they all still use the 5.7 PCM. They just tweak the timing and fuel curves to meet the higher demands of the larger engine.
However, I forgot to mention the MOPAR Performance PCM for the R/T. If I recall correctly, it addresses this dilemma of wanting the SRT PCM in the R/T. I think they basically modified the SRT PCM so it will work in the R/T and accept the R/T vin code and wiring harness.:bigthumb:
It's easier to just tell you what they stand for.i'm confused, can y'all go over that again? and please stop using letters like pcm and vvt, just sayin.
The 5.7's have VCT not VVT. It's Variable Cam Timing. The VVT thing is a internet disinformation. The cam is changing advance and retard via the phasers.It's easier to just tell you what they stand for.
vvt is Variable Valve Timing. When someone talks about a 2009-newer 5.7 they are referencing a vvt motor. None of the 6.1's have vvt.
ECM and/or PCM is the Powertrain Control Module which is basically the engine computer (even though, it controls more than the engine). Some people reference this as the ECM which is short for Engine Control Module.
TCM stands for Transmission Control Module.
TIPM stands for Totally Integrated Power Module. It controls most of your electronic gadgets.
FSM stands for Front Side Module. It is the brains for the TIPM and plugs into the front of the TIPM (hence the name, Front Side Module).
MDS stands for Multi-Displacement System. Most 5.7's have this. No 6.1's have it.
Hope that helps you. Most of these performance and help threads/post involve a lot of these abreviations and it would take up too much space to have to type all of them.
The 6.1 does NOT have VCT the 5.7 does. The tunes are completely different. Also there is no Mopar Perf ecu.Lots of 5.7's have been swapped out for 6.1's, 6.4's, etc.... but, they all still use the 5.7 PCM. They just tweak the timing and fuel curves to meet the higher demands of the larger engine.
