I just received a new SRT oil filter for my Scat pack. No damage to it whatsoever, but the O-ring isn't adhered to the filter. It sits in the groove for it fine, but every filter i've ever bought, the gasket was always glued/attached to the filter body.
Is it defective, or is this typical of the SRT filters?
Thanks
the glue probably wasn't applied properly during assembly. As long as you make sure the gasket is centered when you install it is the important part.
I always start the engine and check for leaks before putting the belly pan back on - just as a precaution.
cold oil @ 55-60 psi on startup will find an opportunity to leak (or spray out) if it wasn't on right
Thanks for the response. I think I'm just going to exchange it with Amazon and get a new one just to be safe. I guess I'm sort of anal about that. I wasn't going to change my old till this Friday anyways.
Thanks again for the response.
your filter is all good. apply a little (very little) film of vasaline to it to help it stick during install and lube it so it doesnt tear/rip.
Agree, or can use a little wheel bearing grease to stick the gasket if need be, absolutely no reason to return that filter.
