Luke,
How does the Keyless Go Push Button Decal ("SRT Start Stop- SWMPB1) install? Do you have to remove the chrome ring around the OEM push button? Does it install with adhesive? Also, is it metal or plastic?
Thanks.
I have one that says Go Baby Go and it is adhesive on back
It's a hard plastic.
over the existing button, make sure to clean with rubbing alcohol, or something similar and we also recommend using a adhesion promoter like available from 3m
Luke
I installed the ignition button, yesterday (see attached photo). It's a small, inexpensive mod that helps to provide a custom touch to the interior. Nice product. Highly recommended.
It was very easy to install. I used alcohol to clean the OEM button and then 3M adhesive promoter to get a tight bond. I also removed the chrome trim ring, but I think that it was not necessary because the OEM button has a beveled edge. Also, I found it best to apply the decal with the angled button in place. This assured that it did not go on crooked.
