Just had SRT springs/shocks from TakeOffAutoParts installed on my R/T and now it sounds like a clunking sound over small bumps. Anyone else ever heard of this? Suggestions? Bad parts?
no - not at ALL!! I have an SRT suspension under an SE with X2Xtreme springs and I have not heard anything whatsoever. Did you do a FOUR point alignment??
Recheck the installation. Something did not get tightened up.
Its one of the sway bars. I had the same noise after a couple of days with my tein springs on. tightened the passenger side and all was good.
Good suggestions, all
Had the 4-wheel alignment done in hopes that it would help (and told them to look around for anything loose). They said the top spring mount assembly might be worn. THat seems odd to me since everything was okay beforehand. Anyhow, alignment done, noises still there...hard to pinpoint where, but I'll look underneath. Do the sway bars get removed/loosened in the installation process? Obviously, I didn't do this one myself.
