1 - 2 of 2 Posts
Looking to buy a set of 2011 and up Srt8 392 spindels
By saying spindles I'm assuming you want the fronts. You are looking for part number 05039030A* and 05039031A*. They were used from 2009 to present 2014 in both the LD/X and LC SRT's. Reason I am giving you this info is two fold. Chrysler calls it a Knuckle(just a FYI) and so you dont limit your search. I found them using a country wide part search engine. I pick up a set from two different JY's for about $150.00 each. Also, the previous part number was from 2006-2008. They should not be mis-matched. Other words if you use one from a 06-08 and one from a 2009+, your wheel allignment may not go into spec. Chrysler requires using a newer upper control arm when using the newer knuckle in an older car. YMMV... Happy hunting
1 - 2 of 2 Posts
