1 - 14 of 14 Posts
I was wondering if it would be possible to run OEM SRT exhaust manifolds with matching Magnaflow HF Catted mid pipes (made for the 6.1/6.4) on my 5.7 hemi? Would this yield a power increase instead of using the stock srt mid pipes? I am planning to do the 6.4 cam swap and possibly the 6.4 intake manifold as well.
Thanks!
2015 Scat Pack
I've seen threads about the SRT manifolds, but not about SRT manifolds with aftermarket mids. I did a search prior to the creation of this thread...
Then you'll know from your research on the SRT manifolds on a 5.7 that you'll pick up a few more horses and have a less restrictive air flow through out the RPM band. Adding aftermarket mids certainly will not hurt. You are going to see even more gains because of your whole exhaust system set up.
Stock R/T exhaust?
You are running SRT mids to stock R/T exhaust to after marker mids then back out the stock R/T exhaust system. Or have you replaced the whole system already.
Dude, I don't know why you don't text me and ask me these things. You can contact me any time.
Discussion Starter · #7 ·
Stock R/T exhaust?
Thanks for the info, I am currently running the Magnaflow Competition system on my R/T.
I am swapping over to SRT8 Kooks Mid-Pipes on my R/T. This will let me install the SRT8 Zoomers catback that I ordered.
For your setup,I would look at some Magnaflow Mid-Pipes made for a SRT8. These would mate up to the SRT8 headers. You would simply have to make the catback fit the mids.
The SRT8 catbacks sound better because of the larger pipe diameter (3" for Zoomers). Probably a little to large for a 5.7L, even with mods, but it should be ok.
After the whole install I would look at getting on the dyno to re tune the ECU to all that new airflow you got going on . Be nice to see what kind of gains you read. Keep us posted.
If you get the SRT8 manifolds, you will have to get SRT8 specific after market mid pipes because R/T aftermarket mids won't bolt up to the srt8 manifolds. Different collector stud locations.
As far as power is concerned, I didn't feel any improvement, but I dyno tuned the car when I had a CAI, throttle body, 180 t-stat, srt8 manifolds and magnaflow catted mids, trinity tuner and I got 353rwhp and 374rwtq so the exhaust must have contributed something towards that. I did not do a before/after test.
That seems like an awful lot of money for only 30whp
You know I hear that a lot. I really hear comments like that after I installed the Modern Muscle cam and made 363hp and 379lb-ft torque. And lost 30+ torque below 4,000 rpms.
When I get my scat pack 392 challenger, I'm sticking to just ARH long tubes, tuner, and a CAI.
The 5.7 responds better to longtubes than it does mids. Longtubes alone will make 30whp. Add a 370 or 374 cam to it and you're looking at some serious power.
1 - 14 of 14 Posts
