1 - 13 of 13 Posts
Just installed the Mopar CAI to my 2016 Challenger R/T 5.7 with Borla Atak cat backs.
The Stage 1 Kit includes the SRT high flow oil filter which is larger than the stock filter.
Recently I have noticed the "Hemi Tick" when first staring up.
Has anyone else experienced this when using this SRT filter?
Thanks
Assume the oil level is good? The oil is the right oil? And is reasonably fresh.
If the tick appeared concurrent with the change in the filter it might be of some value to switch back to the factory filter and see if this affects the tick.
If the tick arises from the change in filters you can elect to stay with the factory filter. Or if the tick is minimal and short lived perhaps switch back to the SRT filter.
However, the tick suggests a lower amount of residual oil in the engine, at least in the lifters or lifter oil passages, upon cold engine start. If the factory filter eliminates the tick I'd be inclined to just use the factory filter.
Hey Rockster,
I had just finished an oil change using Lucas Synthetic.
However I was doing quick startup and shut offs while I was changing the oil.
I'm not sure what significant difference the SRT filter would make over the stock one anyway.
Defiantly considering using the stock filter from now on.
Hmmm, the SRT has a "back flow preventer" or a "Check Valve" if you will, that won't let the oil drain down when shut off so, once the oil pressure is up you should not get the "Hemi Tick".
Discussion Starter · #7 ·
"However I was doing quick startup and shut offs while I was changing the oil."
What?????
fill the oil. start it up. shut it off. check oil. fill again.
Just caught that. Well if it was started with no oil or not enough oil that could be the problem.
No it was full of Oil when started. then shut off and check oil again.
What?????
it was full of oil, then started. Check oil again and fill to full.
Here's the difference in the filters:
It ticks for about 5 seconds when I start it
Try a different filter. Some drain back and cause the lifter clatter and some don't.
'16 A8 Scat Pack
I had that problem on my previous 5.7 with the standard Mopar filter.
The SRT filter eliminated the start up lifter rattle.
Haven't had that issue with my 392. Started using the SRT filter at the first oil change.
1 - 13 of 13 Posts
