Stalling
590 Views 10 Replies 7 Participants Last post by  DodgeCares
I have a new Scat pack 6 speed with less than 300 miles on it. Had for 3 weeks now. It has been perfect up to this point. Yesterday when I first started the car, it had not been started for 2 days, it started fine and I sat there for about 2 minutes and let it idle. I backed out of the garage and it stalled out. I pushed the start button and it started for a few seconds and stalled. This happened the next three times I tried to start it. The forth time it started and it stayed started. I took it for about a 20 minute around town and it ran fine. Has anyone else ever had this happen?
1 - 11 of 11 Posts
Take it to the dealer have them keep it for 2 days and start it and see if they can replicate it.
  • Helpful
Reactions: 1
Had another vehicle manifest close enough to the same behavior. Proved to be the (low pressure) fuel pump. And 6 months later the replacement fuel pump failed and it was replaced.
So fuel pump would be my WAG. But Frank has it right. Take the car to the dealer and describe how the behavior comes about. There might also be factory proprietary errors logged which if is the case will almost certainly shed some light on the failure cause. So this is yet another reason to have the car in for this.
When you take the car in stress that with the engine dying you have lost all enjoyment of driving your new car and are concerned for your safety and that of any passengers. The engine should pick the wrong time to die this can leave you with a car car traveling at some speed with no power brakes and extremely stiff steering.
See less See more
Best thing to do is take it to your local Dodge dealer and have them do a full diagnostics and troubleshoot the issue so they can repair it properly!
Thanks for the tag @Wm.InternetRockDJ!
And hello, @Robert Haman!
We would like to look into this matter further. Please send our team a private message with your vehicle's mileage and model year to get started.
Hannah
Dodge Cares
Ring, ring, ring......."Hello? Dealer, we have a problem....;)
Hannah
Dodge Cares
Hello I appreciate any help you may be able to provide. It is a 2023 Challenger with the T/A Package, Dynamics Package, and Plus Package. 6 speed manual. It only has 267 miles on it.
Ok I am a new user to all of this so I do not know how to send a private message???
Hover your cursor over the member's name. A box will open. Bottom right click on "message". it will only go to that member. AKA "PM".
Reactions: 1
Hannah
Dodge Cares
PM Sent! Awaiting response.
Hello again @Robert Haman!
Our team has since responded to your private message. We hope to hear back from you shortly!
Hannah
Dodge Cares
1 - 11 of 11 Posts
