If you lightly rub your finger over that area from good to bad and back, can you feel any difference in the paint surface?
My initial thought is that the clear coat has been burned through by someone using a direct drive polisher, holding it too long in that spot and causing permanent damage.
But that is merely a guess, and it is just as likely not to be an accurate guess as anything.
More info needed to really diagnose...
