Exactly.the badge size and steering wheel are much different on the 2011
The 2011's have the new dodge "shield" that is both larger and has the crossbar design with "DODGE" in the center of this.I'm not sure I'd want to tackle this on my own. One bad move and you could have that air bag deploy.
BTW .....is the steering wheel badge a rams head on the 2011's? I wonder if Speedy has done this yet?
You can either pull the fuse or simply disconnect the battery. If you do the latter, make sure to leave your trunk open or expect a fun time worming your way into the trunk through the passenger compartment.I'm not sure I'd want to tackle this on my own. One bad move and you could have that air bag deploy.
Brett,If you break the emblem off by force, you are leaving a big hunk of steel inside the air bag, that God forbid if the bag ever deploys, could fly out and kill you..
DO IT THE RIGHT WAY.. Either take the bag apart and remove the clip, or leave alone..
New emblem
And if you want a step by step on how to remove the 2011 emblem I wrote this: http://www.challengertalk.com/forums/f39/how-install-aftermarket-emblem-2011-steering-wheel-63575/
It would likely apply to 2010 and previous cars or at least give you a good idea.
I don't think the problem is the metal coming out during bag deployment as much as it would be the metal CAUSING a bag deployment.I used a small screwdriver to pry the emblem off my 2010,came off with little effort.I cleaned the surface off with rubbing alchohol and my new badge stuck just fine...As far a a little metal coming out during airbag deployment,that will be the least of my worries!
