1 - 3 of 3 Posts
with only 350 miles on it so far, i expect noises that i'm not used to, but this is strange....started the car this morning, about 40 degrees out, shifted to reverse, double pop from the rear with the brake on...same thing in forward. shift back and forth a few times and the same noise continued at each shift..after 5 minutes, it stopped....is something loose?
Not normal
In 6-speed cars the rear winds a little on decel in lower gears but what you are describing is not normal. Take it to the Dealer asap and have it looked at.
the car is an auto....it will only do it a few times, sounds like something external from the diff housing, cant see anything moving...do the CV joints settle in? Is that what is happening? It never makes another noise after that initial few pops.....oh well, off to the dealer for a round of NPF's and some new dings,dirt and scratches. Outside of this new noise, this car is AWESOME!!
1 - 3 of 3 Posts
