Sunday upgrades,X- LUME illuminated Scat Pack Grill emblem!, rear spoiler emblem , new vinyl on the Bumble Bees stripe, wanted the old school look, MOPAR back drop, Scat Bee overlay.. undecided on the Bee overlay? may go with a Black outlined Bee.. thoughts and comments?
OK ,Why did the pics load upside down???
That's what I have. Thinking strongly about the red R/T next year.
Love the wheels. I would do the gray with polished edges but love the Torque Thrust wheels. Are they 18 or 20?
If you grew up in the 70s they don't look out of place........at all.
The overlay is too vivid in color and is obviously covering up something. If it was shaded like the Mopar M under it then it would blend in. Subtle makes more of a statement than bold does, the front fenders already state what the car is.
One thing to think about is the overlays won’t age the same as the factory decals and when you remove them you’re going to see what it did to the originals and then you’ll need to replace them.
Enjoy your car, great color choice.
On the X- LUME illuminated emblem how did you attach it to the grill ? And how did you wireit in ?
You ride looks awesome!!
Right there in your age bracket also, lol
Mounting was a story in it's self, the emblem has 1/4-20 bolts, I had to cut 3/4 inch off them, removed the lower grill above the splitter, and reached up to use the nuts and flat washers, it comes with hardware wire piercing connector and ground terminal,I use a 12 volt tester and found the circuit form the Halo's on the headlight connector, If I remember correctly(you know us OLD guys!)it was the white wire with the red stripe in the underside of the connector, I also had to trim the thin plastic cross bars on the grill to get the mounting bolts through and the emblem level, so today I removed the Scat Bee off the rear stripe, I have all black outlined, the Mopar is a little subdued
