1 - 3 of 3 Posts
Arrington Performance and shopHEMI.com
is giving you a $500 install credit toward
your Magna Charger Supercharger purchase!
Whether you install it here or there, your $500 install credit is yours for the taking.
Call us today - 866.844.1245
HEMI Jeep Magna Charger by Magnuson
Here is the supercharger kit Jeep SRT-8 6.1L owners have been waiting for, the Magna Charger 2300 supercharger. It fits 2006, 2007, 2008, 2009, and 2010 Jeeps with the 6.1L HEMI engine and is a complete bolt on kit. The included tune works with 2008-2010 models only. Most Jeeps will see 100+ horsepower to the wheels at 6 PSI. Intercooled systems are complete with all the components necessary for installation. Included in the kit is a new patented cast aluminum intake manifold, intercooler core, coolant circulation pump, heat exchanger, and all the necessary hardware to complete the entire installation. This system does not require any hood modification.​
Fits:
  • 6.1L Jeep SRT-8 2008 - 2010
  • 6.1L Jeep SRT-8 2006-2007 (Tuning not compatible, use custom tuning)
Features:
  • 2300 Hybrid-roots supercharger
  • Installs in less than 1 day
  • 100% complete bolt-on system
  • No hood modifications are required
  • More power in a smaller package
  • 180° rotation of supercharger provides straight airflow path for maximum power and efficiency
  • Internal Bypass Valve:Valve virtually eliminates parasitic loss(uses less than 1/3 of a horse power at 60 mph)
  • Delivers a proven 30 to 66% increase in real world "under the curve" power
  • High thermal efficiency (up to 76%)
  • 2.4 pressure ratio capability
  • Twin four-lobe rotors featuring 160-degree twists
  • High helix angle rotors
  • Redesigned inlet and outlet ports
  • Improved air-handling characteristics
  • Acoustically designed for noise and vibration reductions
Included Components:
  • 6th Generation TVS MP2300 Supercharger with integral bypass valve
  • Patented cast aluminum high-velocity port intake manifold with integral water-to-air intercooler
  • Intercooler core
  • Coolant circulation pump
  • Heat exchanger
  • Extruded aluminum fuel rails
  • 8 high capacity fuel injectors
  • Front and rear fuel rail crossovers to ensure adequate fuel delivery under all circumstances
  • Predator Tuner
  • Factory "push-lock" connectors
  • Fittings, lines, belts, and hardware
  • Plug and play throttle body wiring extension
Maintenance:
  • Standard 3-year limited warranty
  • Optional 3-yr./36,000 powertrain warranty
  • Nose oil change every 80,000 miles
* Offer only valid through Arrington Performance and shopHemi.com. Special is subject to change at anytime after 2/03/11.​
1 - 3 of 3 Posts
