1 - 3 of 3 Posts
Anyone have any mods that work for getting the power to the ground? I have played with tire pressure but now I'm looking at shocks, bushings etc. for gaining traction. I have went 1.88 in sixty foot but that was once with most being 2.0. I know drag radials will help but I have alot of rubber left on the stock tires.
if you have the 6 speed, i am hearing that a hopnot kit will help quite a bit allowing the car to launch at a higher rpm and the tires to bite down sooner. dont know much about the autos though.
If you want to hook, get some drag radials and save your stock tires for the street. If you are running the Goodyear RSA's, they are greasier than an adolescent's face. Good for cruising, bad for the track. Drag radials aren't cheap, but neither is replacing your rear tires often.
Jack
1 - 3 of 3 Posts
