I am assuming the regular Scat does have a front sway bar, unlike the WB Scat. Is the WB Scat sway bar as good as the aftermarket options?
The Eibach front are 34mm...standard Scat Pack front bar is 32mm / the Scat Pack WB Competition front bar is 34mm
rear: standard SP is 19mm / SP WB Comp version is 22mm
there's aftermarket front bars that range from 34mm - 38mm
To my understanding the WB sway bars are hollow hence less weight any advantage there or is the same as the after market ones?standard Scat Pack front bar is 32mm / the Scat Pack WB Competition front bar is 34mm
So rather I switched to a hotchkis or eibach, WB scat sway bar I would get pretty much a upgrade from my non wb stock sway bar, they will all perform smiliar and I am able to use my own hardware on all of them?I know the Hotchkis front bar (38mm) is hollow; I had one on my first Challenger ('09)
- I believe the Eibach would be as well (34mm) from other posts I've read. I have an AMG / Eibach front bar on my 'Benz and its hollow.
Generally a larger hollow bar can have a higher in.lb. rate than a smaller solid bar - so rather than adding a lot of mass, upsize the bar and make it hollow.
The difference in the rear bar the 'Cat WB rear solid (22mm) is 5.5# heavier than the same 22mm hollow bar for the WB Scat Pack
So the Eibach would probably perform the same as the SP WB bar - if one or the other had a thicker wall, it would have a higher in.lb. rating (stiffer). Its unlikely anyone is publishing information down to that level of detail.
From my (past) experience, I didn't want to have to deal with annual re-greasing poly bushings. The front ones get a lot of heat from the cats / exhaust (despite the heat shields) and they'd groan / squeak when weather got cold or really hot once the grease had dried up.
I went with OEM parts since they use a (rather stiff) rubber bushing that doesn't require / need greasing. Its one less maintenance item to deal with.
It seems it wouldn’t be easier to get eb WB sway bar with the WB bushings, or I can use the WB bushings with Eibach? If I understand correctlyyou have to use new bushings since they all have larger diameter than the stock. The aftermarket ones come with new bushings. For the OEM parts, you order the appropriate bushings (called isolators in the parts listings)
They mount using the stock brackets and end links -
Slingshot engaged!here is a short test drive with the new sway bar
Average speed was about 50
I replaced it on my Rhino Ramps in less then 30 minutes.That's interesting they are 'hollow' . Excellent thread, and great pics !
I guess if I got the car off the ground high enough, this could be a DIY project ? If you have a large enough ratchet /breaker bar.
I changed out front sway bar end links on my D-Ram, Busted my knuckles pretty good on that project. But it was worth it.
Thanks for the Idea !
best regards
parrott
How much clearance did that give you? What I mean is, how far off the ground was the front end? If I decide to do this, I'll be laying on my back on the pavement.I replaced it on my Rhino Ramps in less then 30 minutes.
I have the regular Rhino Ramp which are like 8" off the floor. You'll have plenty of room to work on the front sway bar. I slid from the front...How much clearance did that give you? What I mean is, how far off the ground was the front end? If I decide to do this, I'll be laying on my back on the pavement.
Where did you buy it?I can tell you I just installed the Eibach sway bar on my 2016 Scat Pack Shaker and it's night and day as far as roll and more importantly recovery on hard turns. It's probably the best upgrade I've installed.
what is the part number? went to Fast Hemis and didn't see this one availableMy sway bar will be installed tomorrow.
