21 - 40 of 60 Posts
You can by it from Eibach , I bought my sway bar on EBay same price but no tax free shipping
And I needed fast because I was able to have a lift on a Friday . Seller got to me in 3 days
Part # 2895 .310
JavierA , thanks for your help I went with the back on like you suggested
Really like the way car handles
Reactions: JavierA
Lowest prices I found
If you decided to lower the car I highly suggest the Eibach Pro-Kit. Together with the sway bar the Challenger feels amazing on the turns and completes the package!
995386
995387
Thanks bro
Reactions: JavierA
Discussion Starter #29
I have the pro kit and the strut towers made a difference, hence opening this thread regarding a WB sway bar versus the eibach I figured it can hurt
you have to use new bushings since they all have larger diameter than the stock. The aftermarket ones come with new bushings. For the OEM parts, you order the appropriate bushings (called isolators in the parts listings)
They mount using the stock brackets and end links -
Do you need new hardware when hooking up to the end links? What about the end link bushings?
No you won't need to replace any of those parts unless their worn. I have over 70k miles and almost 5 years old and didn't have to replace anything.
Which mount hole did you setup on? the Inner or outer?
I did the outer first and then after a day I moved it to the inner which is much stiffer on turns. Especially now with the Eibach pro-kit springs it's a different car. So much more fun in the turns. I took it out to a local route which has tons of sharp turns about a mile and a half long. The car rides on rails now.
Discussion Starter #34
Welp I ended up with the 34mm WBSP front sway bar for now, i figured I would go mopar performance, the eibach was my second choice but it’s the same as the Mopar at 34MM so I saw no point in advantages or “better” and I will be using oem hardware as well
What is the part number for the Mopar?
Not exactly! The Eibach has two setting vs. the Mopar only one setting 😏
68386844AA
So that's the same part number I have on my Scat Pack. I think the Eibach is a better option. I'm not crazy about the red paint. But if I get it, I will have it repainted B5 Blue Pearl.
To me it's not about the option of two settings, but the brand reliability.
21 - 40 of 60 Posts
