Hey everyone I’m new to the forms and just wanted to ask a quick question. So I have a 2019 SXT and I purchased the fender flares for my challenger. I have not installed them yet because I am looking to see if I can swap my front lip from the original SXT lip to maybe a SRT lip. Is this mod possible without changing my bumper? I did even see a VZ style front chin splitter I was considering just because I don’t want the wide body look with the baby splitter on I don’t think it would look right personally nor have I seen it done.
2018 Billet SXT Plus
SRT, no, you have to change the front facia etc. Rt + yes, you would need p#s 68258746AB, 68259514AC, and 68259514AC. Easiest replacement method is to pull the front fascia.
I actually found a srt front lip that is made for the sxt & rt I purchase that and it’s coming in Friday so once I have it installed I will upload some photos of it in case someone wants to see how it would look or whatever.
Can be done without removing the front fascia, but it's harder
How to remove front fascia
Oh nice thank you for sharing the videos. I will give it a try without removing the bumper but if it is to complicated for me and my buddy then I will just remove the whole thing and take my time.
If there is adequate clearance to work to install the extension areas on the SRT one, you shouldn't have a problem. I changed my stock SXT for another stock SXT one when the orig. got damaged and it was a 30 minute job with the fascia on and car on the ground.
So you are saying long as I have clearance I will be able to install it with no problem? Did you use jacks stands or you just had clearance from ground level.
I did it at ground level and rotated the steering wheel either way for access to the wheel well fasteners as I did one side then the other. This was on a 2016 SXT.
