Hey Everyone!
thinking of upgrading the stock Air box with the T/A intake kit. See link from Steve white. would there be an issue installing this on a 2020 Challenger RT? The issue that I think of is heat since I the single scoop in the hood is probably to vent the engine heat out. Thoughts?
Hey Everyone!
You should be good, you have the single center scoop style as the TA and SRT 392. That Intake system was made for that hood that you have so your good, your center scoop is not a heat extractor is not to vent the heat out, it’s a ram air vent so it’s perfect for that Intake set up
The pic on steve white site is a RT 5.7L with your hood
This is the kit
The top piece will be installed on the Actual hood vent to bring air to the air box
I tried to install it on my Scat Pack but I had to cover a heat extractors and I had to do a slight modification on the top lid in order to seal I just returned it and did a top and bottom SRT air box set up
Same exact hood as T/A
I put one on my SRT392 with no heat issues. I did also remove the plug inside the passenger side light to throw a little more air in there.
One thing I noticed though. I previously had a K&N Typhoon C/A installed and the intake temps. were no different with that one and the T/A intake.
2015 Dodge Challenger SRT
I did the same thing that @MiHiHemi did ... opened up the passenger side tube on my 2015 SRT 392 to let a little extra fresh air into the engine compartment to offset the loss of what might have been cooling air coming from the previously un-ducted middle hood scoop.
Even in North Florida Summer heat, my Intake Air Temps run 5 - 7 degrees above ambient out on the highway.
