1 - 4 of 4 Posts
2014, dodge, challenger, 3.6
Hey, what’s up. Today on my 2014 challenger sxt I found out my right flash signal did not flash when I locked my doors with the remote. So I tried turning the lights on and it lights up, then I put the right blinkers on and nothing blinks. It’s only the right giving me the issue.
Any ideas of what might be the cause my be. I know my year model challenger
doesn’t have its own fuse.
Plum 2019 SXT AWD
Looks like your bulb is a 3157. Those are dual filament bulbs. I am willing to bet it uses one for the brake light and the other for the turn signal. I would swap your bulb with the one on the left to confirm. I would be surprised if it was not just a bad bulb.
Does the dash light indicator rapidly flash when you turn on the right turn signal with the engine running? It should in this situation. I think there are 2 bulbs for the turn signal, so both having the same filament burned out is a little doubtful.
probably check the front and back - see if the running lights operate.
If the brake lights operate (try 4 way flashers), then that eliminates a fault with the circuit.
as the other post mentioned, does the IP cluster indicate its flashing?
its possible that you might have a bad turn signal switch or there's an issue with the IP cluster.
the "flasher" circuit is within the IP cluster, not a separate flasher relay / module like older cars had
1 - 4 of 4 Posts
