Tail pipe different heights
3822 18
I just noticed that the right tail pipe is about 1 inch lower at the diff than the left. Is this normal?
Auto part Vehicle Automotive exterior Floor Bumper
1 - 19 of 19 Posts
They're all like that from '15s to the '20s. Its more noticeable on the 392 and Hellcats since the pipes are 3" diameter.
The ABS connector bulkhead for the rear sensors is above the right side pipe - don't know if the pipe is done that way for a little additional clearance - there's foil wrap on the wires as well.
Reactions: Charles 236
@Hal H my 2015 RT stock exhaust did not look like that. If you look at the exhaust hanger bracket it looks like the passenger side sits lower than the driver side. But then again I am comparing it to a 2015 RT which has an extra set of exhaust hangers between the tips and the one shown in the OPs pic.
Discussion Starter · #9 ·
If it is normal, then I would expect them to say that. If it is tweaked somehow, I would fix it my self rather than have the dealer screw it up. But if what Hal H says is true, and he sounds informed, then that's it.
Most pictures/videos I find look pretty even to me, but slightly lower on right. The left side tail pipe hanger seems pretty skewed towards the right? That would make it sit higher then the right tail pipe
997257
997258
My right tailpipe angles down lower - OEM exhaust except for the Mopar tips I've added
Land vehicle Vehicle Car Tire Bumper
2021 JEEP Wrangler Unlimited Willys 4X4
@Hal H
Those tips look greatttttttt!
What was the cost....and do you have a part number?
@Hal H
Mopar exhaust tips - P/N 82214613 they run ~ $250
they'll fit on the 392 system with the OEM ball style clamps - they're designed around the slightly smaller 5.7 exhaust, but you just have to seat them firmly and clamp them down.
Like them better than the "Cuda" style tips. Once I found out the square quad tips fit, I got them
Reactions: GSBrockman
The gray car getting the mufflers removed sounded great afterward, I won’t even comment on his music choice.
Will these fit a 2021 Wide body Challenger?These are the best looking tips I could find
yes - on the 6.4 & 6.2 OEM pipes, you'll have to push the tips onto the flange while tightening the ball clamp. They're designed for the 5.7 exhaust, but will work on the 6.4 / 392 system - you have to make sure they're seated (and hold them) while tightening the clamp
Mine is a Scat Pack (Shaker)
Reactions: A Guy
1 - 19 of 19 Posts
