1 - 1 of 1 Posts
The new ORACLE Lighting Surface Mount Afterburner LED Tail Light Halo Kit are designed to give an aesthetic "pop" to the back of your vehicle with an easy installation. This new ORACLE Halo Kit features red polycarbonate lenses that are resin injected resulting in an IP67 rating.These new SMD Halos are installed directly to the outside of the vehicle’s tail light lens making installation easy even for a novice! No Baking or Cutting Tail Lights Required!
The best part is that you pick whether you want just the outside rings illuminated or the center section too! Sold separately, these kits give you the choice to customize the look you want on your 2008-2014 Challenger. Below, this driver opted for just the halos:
Product Specs:
• Now includes FREE Adhesion Promoter Part #2082-504
• Direct-to-Lens Surface Mounting
• Quick Connect Wiring Adapters
• Wide Voltage External LED Drivers
• IP67 Waterproof Rating
• Genuine 3M VHB Adhesive Backing
• Easy Install- No Cutting /No Baking!
• LIFETIME LED WARRANTY
• Fits 2008-2014 Challenger
Purchase: Dodge Challenger 2008-2014 ORACLE LED Waterproof Afterburner Kit
Ring kit includes the following:
  • (2) ORACLE Surface Mount Waterproof Tail Light Halo Rings
  • (2) Quick Connect Wiring Adapters
  • (2) Wide Voltage External LED Drivers
Purchase: Dodge Challenger 2008-2014 ORACLE LED Waterproof Afterburner Kit Center Section
Center kit includes the following:
  • (4) ORACLE Surface Mount Waterproof Afterburners Center Section
  • (4) Quick Connect Wiring Adapters
  • (4) Wide Voltage External LED Drivers
Questions? Drop them below or visit our website (and use forum10 for 10% your purchase)!
1 - 1 of 1 Posts
