2020 F8 Scat Pack 392 6 Speed Stick
Hi all,
I see everyone lowering their suspensions, but I live in a area that road conditions aren't ideal for low profile tires and as the post states, how much taller of a tire would work and has anyone done this?
I have 6 pistons so believe 20" rims is about it rim size but thinking a 275/295 45 series?
Also standard width Scat Pack.
Not doing anything quickly but getting ideas for the next set of tires.
Regards,
Jim
2010 R/T Classic 6M
Well for reference, I had 245/50/20s that slightly rubbed up front. You wanna stay under that. 245/50 is 29.6" tall, 275/45 is 29.7" tall. If you wanna run the absolute tallest possible setup up front without rubbing, 265/45/20. Comes in at 29.5" tall (.1" shorter than my old setup that just barely rubbed, so should clear) As far as the rears i can't help you with that but I know there's a little more room back there
Hi,
Thanks for the feedback, as I see lowering springs which seem to average a inch, so I would think it might work, 275/45 would be 29.74, which are a little over a inch taller than my stock 275/40 would be 28.66.
I might have to try that when the time comes.
Thanks again,
Jim
2010 R/T Classic 6M
Hi,
Thanks again,
Jim
It doesn't rub on the body tho, it rubs on the nut for the ball joint.
Reactions: JavierA
Discussion Starter · #5 ·
Ah, will have to look at that a little closer next time I jack it up
Regards,
Jim
The AWD Challengers use 235/55R19's and they are about 29-29.2 inches tall.
2016 Jazz Blue A8 Scat
I'm currently running 285/45-20s on the back. I have heard that 295/45-20s fit.
Speedometer has been corrected with a Tazer.
I wonder with the 2021 AWD getting 20" what size they will be. I assume 245/45, but who knows.
Yes, same as 20" on current RWD
1003895
It's all in PDFs here
