1 - 3 of 3 Posts
As title says I'm looking for instructions or anything to watch out for.
Thanks,
pwr2tow
Its an Easy task.....about 5 Min !!
- If you've loaded a tune via Predator...Return it to factory
- Meaning load your factory Back up!
- Open the drivers door and remove the plastic cover that's about even with the split for the UPR and LWR dash
- It just snaps in
- Remove the screw that was under the cover
- Remove the screw under the LWR Dash
- Remove the fitted Wire cover under the LWR dash
- It just pulls down
- The LWR dash Snaps in Place....Pry it out
- The TCM will be facing you....with (2) LArge wire bundle pluged into it
Suggestion: Leave the factory TCM in place.....Velcro the new TCM to Old......It works best that way and its very simple to bring the old TCM back on line!
G
Holy schiznitze that sounds easy, thanks a bunch man.
I seen an ad some where on here where they were selling MTCM's for around $225 and I'll be danged if I can find it any more. Any one know where it is, I'll keep looking and post if I can find it.
Thanks,
PWR2TOW
1 - 3 of 3 Posts
