1 - 13 of 13 Posts
Discussion Starter #2
........BUMP........
Very good read. I have not done as many of these upgrades as listed on the original list. A SC would be sweet....
Thanks! The sway bar mod answered a question for me that I did not know how to ask. :thumbsup::thumbsup:
You're welcome, Gila. Thanks for the read!
- Rob
- Rob
I've got another question. Why did you select the Hotchkis over Whiteline, Eibach or Petty sway bars? BTW, I only have two requirements for whatever I go with; the lightest weight that will do the job, and they must be powder coated. Cost isn't an issue here, because there is only about $100 price difference between all of them.
I have wheel hop from hell that I need to cure, and to that end, I have an aluminum one piece drive shaft on order so I can install drag radials, and I'll also be replacing the cradle bushings. I'm sure the sway bars will also help, but that's not the main reason I'll be adding them. I already have Razors Edge 4 point shock and strut tower braces, and am hoping the sway bars will complete my suspension needs. I'm not going to lower the car because I have to go over speed bumps at 1 mph at stock height.
Gila -
No particular reason. There are many good brands out there as you pointed out. Some people are even swapping their OEM bars with Hellcat parts.
Cheers, brother.
Had Pettys Garage install their coil over suspension, front and rear anti-sway bars, end bars, bump shear bushing, and front strut tower brace 5 years ago, 60,000 miles ago. Exceeded my expectations. They put her in their 4 pad NASCAR scale, and did it right...
1 - 13 of 13 Posts
