1 - 3 of 3 Posts
SONAX Full Effect Wheel Cleaner
Precision Wheel Cleaner for safe and effective removal of brake dust and stubborn dirt
SONAX Wheel Cleaner is a highly effective, acid-free and pH balanced rim and wheel cleaner that is safe for all wheels, including aluminum and alloys. This formulation is also effective and safe for use on painted wheels and will not deteriorate clear coats.
SONAX Wheel Cleaner contains unique chemical ingredients that effectively dissolves the sintered iron by forming a water soluble iron complex. During the use of your vehicle, brake dust and road grime become sintered to the surface of rims and wheels due to the high temperature conditions they are normally exposed. Brake dust contains high levels of iron and once sintered to the rim, becomes extremely difficult to dissolve or remove without the use of harsh chemicals.
SONAX Wheel Cleaner sprays on as a thick, flourescent grean foam. As the cleansing foam begins to work into the dirt and grime, the formula begins to turn red. The red coloration is the SONAX Wheel Cleaner forming a bond to the sintered iron on the wheel and changing its state to a water soluble complex for easy removal. Stubborn, baked on grime may take a small amount of agitation. Rinse wheels thoroughly with a power washer and wipe dry.
So here is the test I did over the weekend. First I used this on the VW R32 and got amazing results, unfortunately no pictures.
Was able to do some more testing and the test subject a 2010 Audi S4, with all the bad weather I figured this was a great time to test it out. 4-5 weeks without washing the car (due to rain, snow, northeast winter)
Take a look I followed the instructions to the tee and got some amazing results, dare I say this will be a hit! I'm going to say even better than my favorite wheel cleaner.
Before shot of the wheel
Sprayed it on, and it was immediately green as stated in the directions
Started to turn purple within minutes
Take a look at it cleaning. (this was after quickly using the Uber Spoke Brush and Uber Boar's Hair Brush nothing crazy just a quick brushing)
Used a power washer (Cam Spray) and they looks great!
Needless to say I was impressed so impressed we will be carrying this asap.
I know most know what my favorite wheel cleaner is here and I've been using it for 15 years and I think I just found its replacement.
Sonax Full Effect Wheel Cleaner - $15.95
Sonax Full Effect Wheel Cleaner Buy 3 get 1 Free
Sonax Full Effect Wheel Cleaner 5 Liter Refill
Sonax Full Effect Wheel Cleaner 2 5 Liter Refill
Drive around with that stuff just dried and someone would think you ran over a couple people! Interesting, but I've never been into wheel cleaners, for me it's always been easier to just clean it by hand, I've never found a wheel cleaner that gets it off without actually wiping it anyway. If they invent one that is literally like 90% of them claim (Spray on, spray off and everything comes off without a power washer) I'll be in love, because a day after I clean my wheels they are dirty again...
Nice write up though!
in this situation I didn't need any brushes but in others you may need to use some brushes.
1 - 3 of 3 Posts
