It is a cool little toy to play around with, have heard some bugs happen now and then
Yep, because many of the Enhancers uses the 5 volt Pedal Connector to power it on Chrysler Products
when you loose more then about 0.03 volts it can in most cases cause a Limp Mode and unresponsive Throttle.
Why I would not touch one when I spoke to some people in local Mopar Clubs who have had them trigger it.
As to the Original Poster when you Unlock your PCM and do the Tune for the Supercharger in the Tune Settings
you can virtually eliminate that stock lag all together. Last thing you want to have happen is limp mode when
your punching it or getting into traffic , on freeway, interstate, hwy or intersection. When One of them was telling about the
limp mode he walked over and goes here you can have this if you want it as he handed me the Commander and original
contents box. Told him no thanks and that was more then convincing how serious he was.
That is 300.00 wasted to use a pedal enhancer of any brand. Even an unlocked PCM getting a Tune can not only will gain
HP but it can be set to get rid of Pedal Lag!!!
