1 - 14 of 14 Posts
I have a 2017 challenger R/T auto. The car runs, but won’t go past 50% throttle. It’s not the tune, we changed the throttle Body’s out, 87,92
we checked the plugs on TB for voltage, same says all good there.
Any help please!!!m
If you're revving the motor while it is in park or neutral, it won't go past 3000rpms, it's a protective measure so the motor isn't destroyed.
Sent from my SM-G998U using Tapatalk
Did you change the PCM to a Unlocked one BTW? Also did you put a Tune on it afterwards and the Limiter as mentioned, Did you also change your Fuel Pump and Injectors? There is more then just bolting on a SC and say ok its ready to run.
Discussion Starter · #4 ·
We did a complete swap. The car runs and drives. The issue is it won’t WOT. It still goes the full Rpm range but on the data logging it won’t go over 50%
yes the ecu is new and tuned after Ihave a very good tuner who ishighly regarded on here. It’s not the tune.
2013 R/T
This is close to being normal on mopars. My car scanned with HPTuners pegs @76% but I shift @6k. Your not going to get it to read 100% floored.
Here is a scan played back at half speed. Look at the TPS column. Play it full screen Utube.
It may be something in the tune or sensor. Or a relearn may be needed. I know if I unplug my TB cable with the battery connected, after reconnecting it runs rough abdI have to do a relearn in HPTuners. You can hear it slapping the plate.
Discussion Starter · #8 ·
We did a relearn on all the Tbs. and no 50% is not normal, 75% yes bc voltage of 3.5 reads the same as the 4.6
Discussion Starter · #10 ·
Could you elaborate? I know the max is 5.0 but I’m told 3.5 - 5.0 reads the same for throttle %
Discussion Starter · #12 ·
No, I had one before the build. However we had the tuner change some throttle blade positioning and saw an improvement today.
1 - 14 of 14 Posts
