Customer Satisfaction Notification P01
Engine Timing Chain and Chain Guide
Models
IMPORTANT: Some of the involved vehicles may be in dealer used vehicle inventory. Dealers should complete this repair on these vehicles before retail delivery. Dealers should also perform this repair on vehicles in for service. Involved vehicles can be determined by using the VIP inquiry process.
Subject
Repair
2009-2012 (LC) Dodge Challenger
(LD) Dodge Charger
(LX) Chrysler 300
NOTE: This recall applies only to the above vehicles equipped with a 5.7L Hemi engine (sales code EZD or EZH), automatic transmission (sales code DGJ) and rear axle ratio 3.06, 3.73 or 3.92 (sales code DMP, DME or DMH) built from August 04, 2008 through July 10, 2012 (MDH 080406 through 071008).
The engine timing chain guide on about 50,800 of the above vehicles may fracture. A fractured engine timing chain guide could cause the engine timing chain to break. A broken engine timing chain will result in severe engine damage.
The engine timing chain, timing chain tensioner and timing chain guide must be replaced. Customer Satisfaction Notification P01 Engine Timing Chain and Chain Guide Page 2
Part Number Description
CBPRN291AA Engine Timing Chain Package
Each package contains the following components:
Quantity Description
1 Chain, Engine Timing
1 Guide, Engine Timing Chain
1 Tensioner, Engine Timing Chain
1 O-ring, Oil Pick-up Tube
1 Gasket, Engine Timing Cover
NOTE: Order two heater tube O-rings separately listed below for each repair.
53013736AA O-ring, Heater Tube (order two per vehicle)
Each dealer to whom vehicles in the recall were assigned will receive enough Engine Timing Chain Packages to service about 5% of those vehicles.
Part
