Ok, I've just received my 17 Scat/Shaker yesterday and i have wanted to purchase HK Repo's last month. I've searched and searched on the forums. I want to keep the stock front tires and rim width. I want a big tire in the rear but just want to bolt up. I've read, 295's rub and then they dont, 305's rub but most rebut that , 315"s need a quick persuasion with a 2lb hammer. So I want to purchase bronze HC repo's tonight. 20 x 9.5 in front with stock 245's, Rear 20 x 10 with what I am thinking 305's. Will the 305's work no problem? Now I wanted the 315's but if you use the tire comparison nobody is going to see a 1/2" or so, so I'd rather just bolt and go. Any help would be really appreciated and if any sponsors can answer me I will purchase the set tonight on the spot!
If you are going to go with 9.5's then think about 275's in the front. I believe 305's should be good with an offset. Not sure about the 315's.
I think the max rim width for 245s is 9". So look at 275/40 for the front.
what is the offset of the rims? I just put 20x9 ET 20, and 20x10 ET30 on my 2016 scat pack, with 275-40-20 front and 295-40-20 rear
The rears needed a bit of the fender liner plastic cut out and some gentle persuading with a 3lb hammer.
Don't do 245s in front. They look stretched with a 9 inch rim. Also if you do a 305/35..your back will be shorter than your fronts (245/45..255/45 or 275/40) and that will look disgusting.
If you are doing a 305 Nitto, be warned...they look like 275s from any other make.
I would do a 275/40 front and 295/40 rear
Why don't you just get the 9.5 and 10.5 rear rims.? .I believe Factory Reproductions makes them . Then you can live the dream with the 315s. They wont rub with 20mm or lower offset
Don't do 245s in front. They look stretched with a 9 inch rim. Also if you do a 305/35..your back will be shorter than your fronts (245/45..255/45 or 275/40) and that will look disgusting. It's only about an 1/8" difference in radius(.28"dia). Barely noticeable, if at all.
If you are doing a 305 Nitto, be warned...they look like 275s from any other make. Why is that? The sectional width is comparable to other 305's
315's with 20mm offset would probably stick out beyond fender a bit.
2015 Challenger SRT
FWIW...
275/40-20's...28.6" Dia....at least 9.5" rim...which is stock for SRT's...
305/35-20's...28.4" Dia....and need at least a 10" rim...
315/35-20's...28.7" Dia..and need at least a 10.5" rim.
I run the 305's on my DR's and no problem with fit...
