1 - 11 of 11 Posts
My tires have all been at 32 psi for months. In the early morning, sometimes it’s 29 psi with the cold, but 33 when I get to work. I get in the car today, and all 4 tires read 45 psi?!? I figured it would settle out, but I drove 150 miles today, still all 45 psi. I didn’t bother checking with a meter because, well, I didn’t put air in them overnight, so...
Any ideas what to do about the sensor? Anyone else ever seen this?
How old is your Challenger? The lithium ion batteries inside TPMS sensors may last anywhere from five to 10 years. Five to six years is a more typical lifespan for older TPMS sensors.
Also, many tire manufacturers, such as Firestone and Goodyear, estimate that tires lose one psi for every 10 degrees the outside temperature drops. Your warning light should be triggered by at least a 25% drop in tire pressure. Conversely, under hot weather and highway conditions, the temperature of the air inside the tire rises about 50 degrees. That increases the pressure inside the tire about 5 psi.
Driving your car to work will raise your tires' air pressure slightly. Check your tires with a good air pressure gauge when your car has been parked for at least three hours.
Have you had it serviced recently, tires rotated, inspected? Some garage might have "helped" you. There is an amazing amount of people out there that read the side of the tire to find out what pressure to fill to, and set it to the "Max".
Discussion Starter · #4 ·
Good info! I have a 2019 SXT, so probably not a battery issue.
I hadn’t thought of that, but just Friday I had it at the mechanic because the washer fluid line broke again (and with its location, I can’t get at it like I can when that happens on our Town and Country). I didn’t think anything of it, since it wasn’t there for a tire problem!
The first thing I would do is check them with a gauge. No need to jump to assuming there is an issue with the sensors, if it turns out they're actually showing the pressure that's in the tire. Obviously I have no explanation as to how that extra air got into your tires overnight, but still should rule that out.
Reactions: jkeitz
Discussion Starter · #6 ·
I checked it with a meter and it was actually 45. Someone at my mechanics shop must have “helped” me. I let the air out down to 32 and it’s all good now.
I'd not expect all 4 sensors to go bad at the same time, so if there were really a problem, I'd suspect the control module. Good to hear it was something simple. Welcome to Challengertalk ;)
Reactions: jkeitz
Discussion Starter · #8 ·
Thanks! What a great forum! I just bought my first Challenger in September, I'd wanted one for ages, but had to wait until the kids were off to college. I can't get over the Challenger community. Whenever I pass another Challenger, I get a wave or a flash of the headlights. I put a question here and had answers in minutes. What a great community to be a part of!
I had my first Challenger gesture from another the other day. We were returning from a trip and were behind it a long while and i think he stayed ahead of me on purpose lol. When they went to turn off he put his window down and gave the ✌ sign to us . Ive had mine a bit over a year.
The person who put air in your tires must not have used an air pressure gauge.
Or read the tires instead of the pressure sticker in the door jamb.
1 - 11 of 11 Posts
