@Newoldchallenger Says he has 325s
I think 11"-13" is recommended widths, so the stock wheels should work. Have you looked for 325s? Looks like only PIRELLI P ZERO 325 /35 R20 $500+ each!
If you drop one size in width to a 315/35/20 you will open up MANY more options.
They are recommended for a 11 inch rim (which you have) and are roughly $100 a tire cheaper than 325's to boot.
I also BELIEVE they can be run square ...but please don't take that as gospel.
That is what I have read on other challenger sites from other guys with Widebodys.
I have asked in a thread "Widest front tire on Widebody" but never had anyone post pics.
Hellcat.org has many members w/Widebody Hellcats/Redeyes. Probably a good place to search and double check FRONT fitment. The rears are no problem.
another vote for the 315's.. the aspect ratio will be closer so your speedo will stay within 1% as well.
I have Toyo R888R in 325/30x20 on the 11" OE WB wheels. They are slightly smaller in diameter than P Zero all season OE tires. According to my GPS the speedometer is within 1 MPH, so no problem there. No rubbing at all.
They definitely provide better traction. I run them at 28/7 psi hot.
