21 - 27 of 27 Posts
Larger tires in the rear
Wondering if I can put a wider tire on the back. Currently have 245/45/20 all around.
I read that it will affect my cruise control. If so, I don't want that.
Also, since I need 4 tires, any recommendations on a size that would work on all 4, that are wider?
On the 20x8" 255 is a wide as you should go. You won't see much difference in width, and a little taller. Not worth doing IMHO unless you need new tires, and are buying anyway. A Guy
Discussion Starter #23 (Edited)
I kept hearing that they were coming out with a 'fix'..
never saw anything come of it,, but ask your dealer..
and WIDTH has NO effect on Cruise Control..
Height is only an issue when you use different height tires front to back..
My tires were 3" taller in back..
and the computer kept reading it like I had the space saver spare tire on..
Cruise Control speed limit is 55 mph with the small spare on..
hope this helps..
I prefer this one.
21 - 27 of 27 Posts
