Will the 275/40 20 fit a 9.0" rim with no wear issues? My 2016 SP has the OEM tires, which are the 245/45 20 size. It was mentioned that the 245 drives better. On some cars, a wider tire rides and drives worse than the tire size down that came on the car originally. I was also concerned about uneven wear.
Thanks!
Yes, 275/40/20 will fit on a 9" rim. A much better improvement over the stock tires.
Thanks! I'm checking the different brands on Tire Rack to see which has the better ratings.
Thank you for the updates guys! You would think that FCA would have put the 275/40 ZR20 on the SP as the OEM tire. Of course, it's now available in the Dynamics Package. Perhaps to keep cost down?
