1 - 2 of 2 Posts
I need some help with some rims I got from a whole seller locally, which is being helpful in correcting. The problem is I got 3 of one size rim and 1 of another, and I don't know which to tell him are correct. I found the problem when I went to get tires put on ( 245/45/20 )
If there is a expert out there that could help me tell this guy what size rims I rec'd and which rims need correct.. that would be great.
Thanks in advance.
The photo of the left front is correct. You can see the difference in thickness where the wheel bolts on. This can make a difference in offset. On the "wrong" rim, you can't even see the lug nuts in the pic. Good luck and tell them to hurry up!
Jack
1 - 2 of 2 Posts
