Do any of you have a sensor issue for your TPMS system. I've gone through 2 sensors on my rear right tire in less than a year. Any input would help.
They are generally trouble free. What is yours doing?
Before you blame the sensor for going bad, swap the right rear wheel with one of your others wheels. Then see if the problem moves.
A friend of mine had whatever reads the tires pressure on one of his rear wheels go bad on a Chrysler 300. He swapped wheels, and the problem stayed in the same place.
Unless it has changed, the TPMS receiver is located in RR wheel well area. If you a have any aftermarket electronics, cell phone chargers, USB chargers, Trinity or other OBDII device, temporarily disconnect them. They can interfere with the TPMS and other wireless functions.
