1 - 16 of 16 Posts
A buddy of mine has a '10 RT and is having some trans issues; for some reason it is a pain putting the car in Reverse (MT). It takes some force to get it to go in reverse. What could be the issue here??
The stealership said he needed the following and said the issue was caused by his driving behavior:
Clutch Assy
Flywheel
Throw Out Bearing
Rear Diff Service
For a total cost of $2500ish
This seems a little extreme, any thoughts??
Discussion Starter · #4 ·
I checked how the skip shift was hooked up and it looked like it was right. Any other ideas?
Sent from my iPhone using Autoguide.com App
Discussion Starter · #5 ·
As a side note, it looks like whoever installed it for him, wired into the existing wiring harness. I didn't see the other connector side (black side); sorry for the bad explanation, lol
He bought it from Speedlogix so it should have just hooked right in
There are two solenoids that look the same, same connector just different locations. Skip shift is on the driver's side. If the reverse lockout was disconnected instead then it will be VERY hard to get into reverse. Wife was trying to put it into reverse with the car shut off and couldn't do it. :lol:
Discussion Starter · #7 ·
Soooo...you verified that you didn't connect to the wrong solenoid?? There's no other reason that it would be hard to shift into reverse, IMO.
^^ this is correct - the skip-shift solenoid is angled 45* downward, midway between front and rear of tranny, above the cross member.
The Reverse lockout solenoid is toward the rear of the trans and has the identical 2-wire connector. If the SSE dongle was installed there, Reverse is very difficult to engage, if even possible with a lot of force.
A lot of folks mis-identify the Reverse solenoid as the one to connect the SSE dongle, since its near the shifter mechanism.
2009 R/T
Bump...what he said.
Transmission failures, premature timing chain failures, "mystery dents" that appear out of nowhere, under-performing engines (per ci,)
evil" dealerships, questionable overall quality reported frequently reported, etc. -and- this is CHALLENGERtalk.com.
Good lord !! Leaves one with his head spinning over what the verdict on these car must be at competitor forums ?
Just an observation.
Respecfully,
Gary aka "beamg5"
Respecfully,
Gary aka "beamg5"
Can't blame user error on the car, though... :)
Discussion Starter · #14 ·
He ordered a new sse will put it in this week to see if anything changes. Will keep ya posted
Sent from my iPhone using AutoGuide.com App
2009 R/T
Doesn't matter what SSE you order if you put it on the wrong solenoid. A bad SSE WILL NOT affect reverse engagement IF it is put on the 2ND gear lockout soleniod. Bad SSEs turn on CEL.
1 - 16 of 16 Posts
