1 - 3 of 3 Posts
Hey, chances are this is regular behavior, but I wanted to describe what's happening here.
After parking on a hill, in either direction, the car slides slightly after letting the foot off the brake, then I turn it off and all is well. However when I start 'er up, and shift from park to reverse or drive (depending on the direction), the transmission shifts with a JOLT.
I'm not talking about a nice click or anything like that. It really audibly jolts. Anyone else experience this and know why it happens? Mine is a 2013 SXT.
When you park on a hill you must use the correct procedure or you will get the described result.
--apply foot brake
--shift to neutral
--apply parking brake
--release foot brake
--let parking brake absorb load
--shift to park
When leaving be sure to put in gear before releasing parking brake and you should have no more issues.
When you park on a hill without using the park brake, the parking pawl in the transmission is taking the whole weight of the car. It's under a lot of strain. So jolts, bangs, etc are to be expected. Use the parking brake.
1 - 3 of 3 Posts
