1 - 20 of 30 Posts
My car sits outside covered for the winter. Is it possible to hook up a trickle charger underneath the hood or does it need to be attached directly to the battery in the trunk?
2009 Challenger SRT8
I attached a trickle charger to the posts under the hood for one winter and it seemed to work fine. I think to the battery would be the preferred method and you can get the trunk shut if your extension cord is not too big.
2015 Challenger SRT
Am I old fashioned in that closing the trunk tight with the battery being charged is not a good idea...Let it breathe a little...fumes if any are not good...
..but then the little trickle chargers don't put out much current...So probably no Kaboom...
Battery is vented to outside via a vent tube so fumes are not an issue. Alternator charges your battery going down the road so it's the same thing.
I'd have to use 100ft heavy duty cord so closing the trunk would not work. Running the cord up through the engine bay would be ideal.
2015 Challenger SRT
I learn something every day...Thanks Slidd
That is what I do. It works fine.
With no real winter here in Georgia there is no real need to trickle charge but when I know I wont be driving if for a while I have a neat little setup I made a long while back. The way my garage sits the sun hits the side closest to the rear of the car so what I did was mount a 2'X4' solar panel outside and ran a cord into the garage. I made a little deal with connectors to the battery and ran the main connector so it will hang about 2" when I run it down through the hole in the floor (I keep it tucked inside and a rubber plug in the hole when not used). So when I want, I open the trunk and push the connector out and connect it to the connector from the solar convertor and it trickle charges for free. Maybe silly a bit but I do use it on a few different things like rechargeable batteries etc. as well.
I’ve ran a Battery Tender on mine for 2 winters now.
No problems.
I swear by Battery Tender. I have 2 Sportsters, a lawn tractor, an emergency generator and my Challenger on them as I type... there's a green glow in the garage at night. :) It's great knowing that when the cover comes off, the vehicle WILL start.
Paul
My Challenger has been sitting safely in a warehouse since Hurricane Michael hit. I've been searching for the best trickle charger I can find and have read many articles stating "Best for 2019" etc.
Problem is, all these websites post up their top picks but when you read consumer reviews the difference of opinion differs greatly.
For those who have to store their rides for extended periods, which trickle chargers have you found to be the most reliable?
2015 Challenger SRT
Paul
I have 2 Battery Tenders ...The 3 AMP ones...One for a Jag that sits a lot and for my '71 Chevelle...
1 - 20 of 30 Posts
