After a recent rain storm, my ABS light came on.
When I took my 2009 SE in for service, the techs found my trunk had taken in water somehow, (not from the trunk seal) and caused the air restraint system to fail. Just a heads up.
Were you ever able to figure out where the trunk leak was coming from?
I have a small trunk leak in my 2009 Challenger SE. I think it’s my tail lights or somewhere around the gas cap...
I had the same thing however in my case there was probably 3" of water in there. The battery terminal were quite corroded. I set a fan in there, opened up the trunk and let it dry out for a couple days. No idea where it's coming in from. I can't see how it's getting in through the trunk seal though as it's elevated...
I had a trunk leak in one of my other cars. The tech climbed into the trunk with a flaslight and closed the lid. Water, from a hose, was then poured around the trunk seal, starting at the top. Then, around the edges of the lights. The leak was quickly found and fixed.
