Thank you, can you suggest any HP tuner models that would be the best? I'm trying to learn how to tune, so it will be a little project. I'm unsure of what i have to switch for tuning for long tubes and catless pipes, any suggestions / tips are appreciated very much haha
Thank you all!
So HP tuners has 2 versions:
- standard interface that allows you to read/write/log - $299
- pro feature which allows you to also log analog signals (i.e. wideband, fuel pressure sensor etc..) and standalone data logging for other vehicle models (not available on dodge vehicles) - $549
Then you need to purchase credits ($49.99 per credit). To tune the PCM it requires 2 credits, to tune an A8 TCM I think it is 4 credits. Credits are only needed to write a tune to a vehicle Once you apply the credits to a vehicle you get unlimited tune writing capabilities but for that vehicle only...HP tuners essentially remember the VIN.
You will also need the PCM or TCM unlocked. I believe for the PCM it is $250...not sure about TCM (I have a manual so never paid attention).
If you go with the standard interface and you only plan to tune the PCM you are looking at $649. I think you still can log AFR if you use an AEM wideband that interfaces with the OBDII and uses the CAN bus to stream data .
https://www.hptuners.com/product/aem-x-series-obdii-wideband-afr-controller-gauge/
If you go with the pro interface and plan on tuning the PCM and TCM you are looking at ~$1100+TCM unlock.
Now, don't expect to buy HP tuners and hit the ground running. There is a significant learning curve. My suggestion is you read the links in this post and become a member of the HP tuners forum so you can ask questions if you get stuck.
https://forum.hptuners.com/showthre...he-basic-steps&p=525502&viewfull=1#post525502
I highly recommend you have a bung installed in the LT headers so you can install a wideband O2 sensor which will allow you to tune WOT fueling accurately. This should be a minimum requirement regardless if you go with DS or HP tuners.
