Just this evening my right turn signal started flashing twice as fast as the left turn signal. In the past, this always meant that an element was burn out in a bulb on the right side of the vehicle. I can't find anything burned out.
What gives?
If a bulb is intermittent, if resistance is low, there is also a flasher module, even TIPM a possibility. You do not have the sequential tail lights, correct?
No sequential tail lights have been installed.
swap the stop/turn/tail bulb(s) from right to left and see if hyper flash follows to left blinker. If still on right blinker, swap front turn/park bulb from right to left and see if hyperflash is on left blinker. replace bulbs as necessary
Discussion Starter · #5 ·
Thanks for the replies. I replaced the 2 right rear bulbs and the problem went away.
Thanks, it's actually good that was the fix. Better the fix be common rather than start seeing odd issues causing this
Reactions: F8HemiRT
