So I have suddenly developed an issue where the remote start stopped working, it was working on Friday...and since Saturday, nothing.
No change (tail light bulbs were replaced) and all i get is a single light flash and no remote start.
I checked and the hood plunger operates as normal, took it off and checked on a VOM.
Windows are fine, nothing is open, I am just not getting any remote start. Yesterday I scanned it and only can bus codes I had were the heated seat (more on that in a bit) and a stored Airbag code from when I unplugged one under the seat once.
As for the heated seat issue, I have had them work intermittently for about 8 months, and tried the usual things of checking connectors, harnesses, I even swapped in a new heated seat module, and since I had an extra on the shelf, the climate controls and heat seat switches! nothing changed. When I ran the scan yesterday it came up a U0208 code which is lost connection with heated seat module. But I do not know where to start searching that one, maybe a broken wire? the 2011 up heated seat module only has the two connectors on it so it is not like the 3 connector model on the pre 2011, and I can't find a wiring schematic for it.
Any suggestions from the guys out there?
Discussion Starter #2
So I have done more checking and the reasons for remote start not working are
IF THE ENGINE STALLS OR RPM EXCEEDS 2500 Not an issue as car is not starting
NORMAL TIME OUT RUN MODE (15 MINUTES) Also not issue
CUSTOMER MOVES IGNITION INTO RUN/START Non issue as no fobik in car
ANY VEHICLE DOOR AJAR all doors and trunk + hood closed
TRUNK/LIFTGATE AJAR trunk closed and secured
HOOD AJAR hood closed and secured
FUEL LEVEL LOW tested with everything from full to 1/4 tank
START COUNTER REACHED non issue as not starting
LOW RPM SHUTDOWN non issue as car ot remote starting
FOBIK IN VEHICLE Only two fobiks, one in pocket, one in house
BRAKE PRESSED no brake applied, as nobody is in car
THE HAZARD SWITCH IS PRESSED Hazards no on
NOT IN PARK OR NEUTRAL car is an auto and it in Park
VEHICLE SPEED HIGH non issue as car is park while testing
VTA ALARM TRIGGERED alarm not triggered
PANIC MODE ACTIVATED panic mode not triggered
BATTERY VOLTAGE HIGH voltage confirmed at 12.8 volts
BATTERY VOLTAGE LOW voltage confirmed at 12.8 volts
LOSS OF BATTERY VOLTAGE Battery in good condition and loaded tested correctly
MIL ON no MIL or stored codes
LOW OIL PRESSURE Non issue as no remote start...plus oil pressure good
COOLANT TEMPERATURE HIGH non issue as not starting and coolant temp is within spec
CRANK NO START non issue as car is not remote starting, but starts with button or key
RKE OFF MESSAGE No message displayed
VEHICLE NOT CONFIGURED Remote start worked for 2+ years with no issue jsut stopped on Saturday
HOOD SWITCH NOT INSTALLED OR INOPERATIVE hood switch removed and tested with meter, and is known good
NO AUTOMATIC TRANSMISSION NAG1 trans operating correctly
IGNITION SNA
IGNITION NOT IN LOCK
VEHICLE IN SHIPPING MODE
VEHICLE NOT PROGRAMMED
So still not sure, I am hesitant to take to a dealer as 1. I am not keen on paying for a feature I already had 2.I do nto truly trust others to work on the car.
2012 blackberry pearl R/T Classic
I had a fob fail as you described.
Dealership had to program a new fob, after that they reprogrammed the old one.
Probably won't work, but try hitting your lock button on fob first then try the remote start.
After doing some short research on this looks like most people have to take it to the dealer :( to get this fixed it's typically something with the computer, saw one where it was showing hood pin as open even thou it was closed and had to be reprogrammed. Good Luck!
