1 - 16 of 16 Posts
Hello, I have bought 2016 Challenger SXT 3.6.
Car is really Brilliant.
I want to do 2 modifications and I have a questions about that.
1. Wheels : What maximum size can I mount?
I want to buy 20" rims 9". What tires can I mount on front and rear wheels? I heard that max is 275 all over is it right? Maybe better mount 275 front and 295 rear? Is it possible?
(Mark: i want to have 40 or 45 profile)
I mean that rims: www . amazon.com/OE-Wheels-Challenger-Charger-Chrysler/dp/B01CILD1DG?ref_=fsclp_pl_dp_13
2. I want to mount Hellcat bumper and SRT hood to my sxt. Will be fit ? is it plug and play modification?
I mean that kit: www . ebay.com/itm/2015-19-DODGE-CHALLENGER-HELLCAT-STYLE-FRONT-BUMPER-COMPLETE-CONVERSION-KIT-/263455610984
What do You think?
Thanks!
Welcome to Challengertalk ;) My 1st question is, do you want to go square, same size wheels all 4 corners so you can rotate? On a 9" rim, the biggest suggested tire is a 275/40R20. Can you mount a 295 on a 9" wheel? Yes, but the footprint won't be much larger, and it won't seat quite right. I'm sure there are people who have done it and would report no issue, but best recommendation is not to.
Now, if you want to do staggered wheels, you can do 9" in front, and 10"=11" in the rear. You can mount 315/35R20's on 10.5"-11" wheels with the correct offset. The wheels you linked to on Amazon are OE Hellcat reproductions. Hellcat reproductions are available elsewhere too
OE Wheels also come in other colors and widths
Factory reproductions also does Hellcat replicas, they have 9.5" and 10.5" ( you can mount 275/40R20s on the 9.5" for the front)
Voxx does Hellcat replicas in 20x9 and 20x10.5 as well, but only matte black
The Hellcat conversion and hood would fit, that ebay listing you link to are not Mopar parts, be aware. I can't speak to the fit/finish/quality. Correct Mopar parts will be more expensive, IE:
No matter what Hellcat conversion you use, you lose ability to use the fog lights
Thanks For Your message!
1.I want to mount9" with 275/40 tires all 4 wheels , or 275/40 9" (front) and 295/40 10" (rear) . Will be ok ? Can i put that wheels on front and rear without problem? Which option is better?
2. Im from Poland so if i buy from USA i need do pay 45% fees. Kit for 1500$ takes 2500$ final price... its too much. I think, maybe better is find OEM used parts in europe? Or buy this kit from Taiwan? From link upper. It looks really good and is complete set.
Fog lights i dont need so its no problem :)
If you want all wheels the same, then 275/40R20 on 9" or 9.5" wheels, as I said 295s not recommended on less than 10", will fit on 10" just fine for rear. I can't speak to acquiring parts for Poland, sorry, you'd want to source locally if able.
Perhaps? http://car-part.com/polish/
Yes, if that's the sizes you want
The original size used on Challengers are 245/45R20 and 275/40R20. The 295/40R 20 will be a bit taller, the 295/45R20 would be considerably taller
Your correct choices would be either the 295/40R20, or the 295/35R20
977954
977955
977956
Ok, so i will go to set:
FRONT: 9" x 20 rims with 275/40/20
REAR: 10.5 X 20 rims with 295/40/20
And the last question: won't the front wheels rub against the wheel arch when turning?
No, 20x9 with 275s were OEM on some trims. The fenders are rolled on 2015+, as long as the wheels are the right offset, and OEM and the replicas are, you'll be fine
(y)
If you get reproductions, either Hellcat or Demon, they each only have one offset listed for our cars and the 5 x 115 bolt pattern (FR70 9.5" +15, 10'5" +25, FR73 9.5" +12, 10.5" +22/ Voxx Demon 9.5" +20, 10.5" +25/ HR5 9.5" +15, 10.5" +25, etc.) these have been proven to fit
If you get aftermarket wheels with custom offsets available, you'll want to check with the retailer to see what's known to fit. Usually within these ranges
1 - 16 of 16 Posts
