Is there any chance that you can powder coat these in silver? Regardless, I'm interested in a set, silver or black. Can you PM me please when they're available?:rocker:
Is there any chance that you can powder coat these in silver? Regardless, I'm interested in a set, silver or black. Can you PM me please when they're available?:rocker:399 is correct. Over the next few months we will have available most LX chassis parts from Strut Bars, Rear Bars, Crossmembers, Frame Connectors, and items like door and hood prop rods and more. You will notice that we strive to build the best quality parts available and a great price. We also install everything we make plus more.
These look good. But my concern is with the adjustment bolts bending under stress (I like going around corners). What guarantee can you give me that this won't happen to me again, because I had this happen with a set of adjustable camber arms that I bought for my Speed3. I bent one of them at the adjustment point while running The Dragon.Here are pictures of the Rear Adjustable control arms. We will be offering 3 colors. red, orange, black. Next up we are working on a bolt on wheel hop reduction kit that will not require taking the cradle out. Front Strut braces are getting close to.
Remember that $399 dose not include installation.I'm having my post-lowering alignment done today, and I provided the rear camber bushings 66050 in case they were needed. Guess what, they are. And it bumps my alignment cost up another +$325 to install the rear bushings. About $500 total alignment cost. I verified this with two alignment shops, cost is similar both places if the rear bushings are needed.
So...$399 for the adjustables? I would have done that in the first place had I known. And if they had been available.
You need to order these to adjust the front.having the same issue with this guy, too.
but in both right front camber and right rear camber and thinking about ordering one of these bushing as they're cheaper and seem like a good easy solution.
my question though: Isn't the front camber adjustable? Or do I need to order 2 pair of these bushings, and if so, will they fit in front or they're only for rear.
The difference is that you can install those in your garage fairly easily, then drive it over to an alignment shop. The bushings need an alignment shop to read your current alignment first so that they know how many degrees to install them. You'll be a couple of hundred $$$ into their labor before it's done.Remember that $399 dose not include installation.
Thats for those who have a garage and the tools and skill. Just saying it maybe a wash between the two.The difference is that you can install those in your garage fairly easily, then drive it over to an alignment shop. The bushings need an alignment shop to read your current alignment first so that they know how many degrees to install them. You'll be a couple of hundred $$$ into their labor before it's done.
How different are the camber bolts to the front control arms?The front camber is not adjustable but you can buy camber bolts to adjust the front camber. The camber bushings for the rear will do the job.
I think that's it, plus the most popular and famous aligning shops here use some kind of liquidy metery thingy instead of Hunter and... Etc.Im pretty fluent in ******* so Ill guess...
with MacPherson strut cars we used to loose everything and then "pull" the wheel out while another guy tightened everything up to get some camber on a non adjustable setup,aka junk suspension design.
That might be what they are talking about.
I'm so confused and I don't even think alignment shops here know these things.
The only advised me to do something they call "Pulling camber/chassis"...
Please note that I have a 2016 SXT Plus Challenger.
I have a set of these. Put 'em on the same time I put my springs and swaybars on. Can't beat 'em.I installed both of them for the same reason, once I lowered my car, they couldn't get it back into a proper alignment, so it wore out a set of tires on the inside treads. The front upper control arms are not really that hard to change, maybe a 6 on a 10 scale of difficulty. The rear concentric bushings are junk. They are aluminum bushings, pressed into stamped steel control arms. Didn't take very long for them to roll in the sockets. I've since bought these for the rear. You'll need a set of upper front position, and a set of upper rear position bars.
Adj Rear Upper Lateral Control Arms (Rear) | Charger, Challenger, 300C
Adj Rear Upper Lateral Control Arms (Front) | Charger, Challenger, 300
Actually No.you have to change the camber arms in order to adjust the camber in the rear of these cars, dodge has a camber arm + and camber arm - depending which way it needs to go, im not sure how much adjustment you get out of them though.... something does appear bent on that right rear however.
You can easily see various types including adjustable upper and toe link at americanmuscle.comPictures of these control arms? I'm gonna buy a set soon.
