1 - 13 of 13 Posts
Well got my UPR catch and lines installed about a week ago. Checked it today and already collected this much oil. Daily driven to work, about 20 miles each way, mostly highway. So figure 200 miles or so. Glad I decided to do this install.
I installed the UPR piece in my Scat, definitely worthwhile mod.
UPR ?? whats the brand of your catch can? wouldn't happen to have a link too would you ? :)
What type fitting is that going into the intake? Part number?
The fittings came from EARLS plumbing. They are standard 45° male AN to male NPT hose adapters. Specifically -8 AN to 1/2 NPT (pn# 982388).
https://www.anplumbing.com/adapters/aluminum-adapters.html
I drilled out the NPT side to 15.5mm to slip over the plastic nipples on the manifold. Then secured them in place with setscrews. I didn't want to modify the manifold itself. Put some shrink wrap over the male pipe threads to dress them up a bit. Any other brand in that size should work fine. Just been using EARLS for years.
2016 Scat Pack Shaker
Nice installation. IMO Looks better than the standard installation using z bracket.
Reactions: CaliforniaShaker
1 - 13 of 13 Posts
