HIDs are nothing new to me but why i keep having this problem on my car is besides me… This has been an on going problem I've been having with a couple kits I've had. Everything was working fine and my headlights would always turn on. I have the 55w kit and all my connections are soldered and grounds located at factory places. Last night my headlights wouldn't turn on suddenly, then 10 minutes later they randomly come on. This happened again today. Now they won't turn on at all. I got a DMM out and tested a spot on the power wire at my 12v and its getting power from the source, past the fuse. Once it gets to the relay however i no longer have 12v as i tested the power wire and ground that connect to the actual bulb. Something keeps happening to my relays causing them to go out. What is going on here?
Its worth noting that i also have HIDs in my fog lights and never once have they not turned on. Ive had to replace relay harnesses over and over with my headlights to solve the problem until eventually it would stop working again. So when i got the 55w kit i replaced everything thinking that might solve it… apparently not… I'm baffled as to whats causing problems here.
