2019 Sublime Shaker and 2010 Detonator Yellow R/T Classic
will 2014 v6 front springs fit 2017 r/t scatpack
Yes, they will fit, but why do that??? The V6 springs are longer, they will compress a bit more with the heavier R/T motor but not as much as you think.
Terrible idea.
also bags are probably bot the best choice either unless you wanna for out a lot of dough.
Try a matched set of shocks/springs from a company like eibach. Coilovers would be the next step up. Then bags
Sent from my LG-H910 using Tapatalk
2013 Challenger SXT
Old 1/4 mile racer trick, v6 spring in a v8 car, the taller v6 spring stores more energy, so when you launch the front comes up faster to put more weight on the rear tires. Run the v6 spring with a 90/10 drag strut. front end should really pop up on launch real nice and the 90/10 will help hold the front end up. Run some skinny's and remove the sway bar, take off the front bumper..............were does it end.........lol.
Another trick cut a coil off the rear spring, increases spring rate to help control wheel hop and helps to plant the tires, combine this with some 50/50 shocks.
Believe it or not, I have already taken off sway bar, added skinnies, big tires, gutted the car, and the seats and bumper are next. I do have a hard time finding a 90/10 shock.
