1 - 3 of 3 Posts
Hey all,
I'm close to purchasing a set of new wheels and tires for my 2015 Scat Pack and I've been reading some conflicting information when it comes to offsets and sizes. I searched around as best as I could so I was hoping to try and get a straight answer from someone before I pull the trigger.
I'm looking at these rims for front and rear, so 20x9.5 with an offset of 18mm along with 275/45ZR/20 Atturo AZ850 tires for the front and rear. From what I've read there should be no issues at all with these tires on a 9.5" rim since they technically would fit fine on a 9" but I'm not sure about the offset. The only other thing I'm unsure of is TPMS. Can I just have the existing TPMS swapped over by the installer?
Would this set be a straight swap without any spacing or anything needed? If it matters, I have the 4 piston brembos. Thanks in advance!
Looks to me that you’re good to go, although I can’t comment on the brake clearence. TPMS Sensors can be transferred over to your new wheels no problem. The shop might charge you to put some new gaskets on their or w/e but it shouldnt be any issue. Good luck!
That's pretty much all I needed to know, thanks!
1 - 3 of 3 Posts
