1 - 14 of 14 Posts
Hi all .I try to swap full front (bumper ,grille ,headlights from 2013 up to 2015-2019 ) but troubles come from non understand .
Whats go wrong ?
1)I bought from breeeze full set front swap .
2)remove all old parts and begin install new
3)all parts install normal except LOWER REINFORCEMENT
4)If I try to install LOWER REINFORCEMENT - all angles of installed parts go to wrong view
I try to inspect LOWER REINFORCEMENT - think all looks normal , but something wrong if I try install it in to car
I try to found same parts number (just think about fake parts ) but absolutely doesn't found anything with my numbers from sticker
I NEED YOUR ANY HELP ,I don't know why all go wrong.
PS- I upload some photos - photo of full car view - all angles ok all place is correct but LOWER REINFORCEMENT doesnt installed ,but after LOWER REINFORCEMENT install - all angles go crazy
THX to All for any ideas and any information about this problem
I can't personally help you but I have seen other people have that problem, I believe that it is related to having the part behind the bumper on in the wrong order. I'm sure someone else will reply soon.
we can tell you which parts are needed, but if using non OEM parts, have no clue
basically everything in front of crash bar must be replaced!!!
again if using non oem parts, have no idea
everything forward of #1 must be replaced
989185
1 - 14 of 14 Posts
